Message 11 of 13
Re: Home Essentials price hikes
The only BT staff here are the mods and they don't have access to customer accounts.
Message 12 of 13
Only observations:
@callaghankieron
You  should check precisely what package you are on currently  ?
   I would recommend you check what Home essentials package you are on currently -  you should have that information via  MY BT  - eg under the broadband section  and it should appear when viewing your bill ?
If you are phoning BT customer services you could ask them that precise question.
With that knowledge - determine or question  whether you are on the most appropriate package  given your broadband speed and (No) income. Next question whether you are on the correct standard price  for that package.
On a general note OFCOM  publishes on it website
https://www.ofcom.org.uk/phones-and-broadband/saving-money/social-tariffs
Last updated: 17 August 2026
what they describe as
Full list of broadband and phone social tariffs
Message 13 of 13
Thanks so much - the help I was looking for!
