Message 1 of 6
How do I close my Account.
Hi,
I've been with BT for a while, but can no longer afford it.
I want to close my account, but I can't find an email address to contact BT.
The Chat/Message service doesn't seem to be operational and I definitely don't want to spend an hour or so waiting for someone to answer the phone.
Can anyone help with an email address?
Regards,
Paul
5 REPLIES 5
Message 2 of 6
Re: How do I close my Account.
there is no email address to cancel your account and you need to phone 03301234150.  if you are still in fixed term contract then there will probably be early termination charges
Message 3 of 6
Just call, instead of posturing about "hour waits" I honestly couldn't tell you the last time I had a await that long when calling, been getting answered pretty much straightaway recently
Message 4 of 6
Hi @pebbleridge13,
As others have mentioned, our lines should be quick to call at the moment.
If you would like our help closing the account, we can do this for you. I'll send you a private message so you have the option to message us. Please note, it can take us 1-2 working days before we can get back to you.
DanielS
Message 5 of 6
Hi @pebbleridge13, thanks for getting in touch via PM.
As you're moving to another provider on the Openreach network when they transfer the services over to them your BT account will close automatically.
Cheers
John
Message 6 of 6
Hi, regarding Chat not working.
It didn't work for me via Chrome, but was ok via MS Edge.
It'll inform you to ring if you want to leave though - so they can make you an offer.  It can be much cheaper elsewhere though if you just want a basic service, so shop around if tempted.
