Anonymous
Not applicable
Message 1 of 4
How do I remove an old Account from MyBT ?
I've got 5 accounts showing but I only use the 1 now. Can I get the others removed?
3 REPLIES 3
Message 2 of 4
Re: How do I remove an old Account from MyBT ?
Hi @Anonymous and thanks for posting.
I can get the old accounts removed for you. I'll need a few details so check your inbox for my message and drop me a reply.
Cheers
David
Message 3 of 4
Hi @Anonymous.
Thanks for sending over the details. That should be all sorted for you now. Post back if you have any other problems.
Cheers
David
Anonymous
Not applicable
Message 4 of 4
@DavidM Can confirm all sorted now. Thanks for all your help 👍
