Message 11 of 16
Re: Hub 2
Ok that's good to know, thanks for your reply.
Message 12 of 16
Re: Hub 2
I thought it's the hub as the charge is alot for delivery.
Message 13 of 16
Re: Hub 2
The member of staff said I would need a new hub and the charge would be£ 10.99 that's when I queried it and said I'd never paid for one before.
Message 14 of 16
Re: Hub 2
£10.99 sound like it is a delivery charge. If I were you I would call BT Billing 0330.1234.150 and ask why you are billed for delivery.
Message 15 of 16
Re: Hub 2
@Sue41
The DV phones connect to the SH2 using DECT not WIFI so a drop in your WiFi will not effect your DV phone.  This has been covered numerous times on the forum
Message 16 of 16
Re: Hub 2
Thank you il ring them again.
