Message 1 of 7
I need help creating a BT ID
Because of a technical issue I can't create a BT ID. I have tried multiple times to no avail and I need it to set up my broadband properly. Can someone please guide me through this?
6 REPLIES 6
Message 2 of 7
Re: I need help creating a BT ID
Can't help with creating a BTID, but not sure what it is regarding setting up your broadband that you can't do because if lack of BTID.
Message 3 of 7
See help page.
https://www.bt.com/help/account-and-billing/what-is-a-bt-id-and-how-can-i-get-one-#:~:text=You%20may....
You do not need a BTID to set up your Internet connection.
Why do you think you do?
Message 4 of 7
I'd like to have the account to make full use of the app and to set up the hybrid connect that I'd be receiving within the next couple of days.
Message 5 of 7
To make full use of the app and to set up the hybrid connect that I'd be receiving within the next couple of days I believe I need the ID.
Message 6 of 7
Don't I need it to set up the hybrid connect?
Message 7 of 7
No, you can set the Hybrid connect up without the MyBT app or a BTID.
https://www.bt.com/help/bt-halo/getting-set-up/setting-up-hybrid-connect
What error are you getting when trying to set up your BTID?
