Message 1 of 8
Kit return. I'm getting hassled
I sent my broken TV kit back to BT some weeks ago and i keep getting hassled by text about it. It's annoying, I'm 85 years old & could do without the extra stress.
For some reason when I put the RM tracking number it keeps saying unable to do and check tomorrow
Can someone from BT please look into this?
Acc no: ***
Tracking
[Mod edit: Removed personal information from the community]
7 REPLIES 7
Anonymous
Not applicable
Message 2 of 8
Re: Kit return. I'm getting hassled
just go live chat and give them the info they ie tracking number aslong you can prove you sent it via the tracking number they will stop hassling you
you might want to remove tracking number  an account number from this post this is a public forum every can see this use the edit feature
us  this https://www.bt.com/help/contact-bt/account-and-billing/tv
use message us feature
they will need a few account details to verify its you
dont put them in reply to this post use the info in message us
once varified tell them you sent back the eqipment and give them the tracking number
Message 3 of 8
It is taking in excess of four weeks to update accounts after an item has been received. If you call BT Billing 0330.1234.150 with your Proof of Posting or your Proof of Receipt they can update your account.
Message 4 of 8
Thanks, will get on that soon as possible.
Can't seem to edit the original post though to remove tracking.
Message 5 of 8
You can only edit a post for one hour after it has been posted. I have asked a moderator to remove it.
Anonymous
Not applicable
Message 6 of 8
this 3 dots press on it and see if it says edit if not the maybe a time limit on edit or may not be signed in
if you are and you still canr do it maybe a mod can edit this fo ryoy
Message 7 of 8
must be a time limit as i tried that. thanks anyway.
Message 8 of 8
If Royal Mail site don't have the tracking data after this time it is likely that the scanning of the package was not successful (they do I believe retain tracking records for over a year) so the advice given in this thread to contact BT is the way forward.
