Message 1 of 3
Leaving BT
Hi, I have 46 days on my contract and have decided to move to a cheaper service. When is the best time to switch so as to avoid any fees and not to over pay.
2 REPLIES 2
Anonymous
Not applicable
Message 2 of 3
Re: Leaving BT
Default always used to be 14 days from order, so 14 days from end of contract. But a few days either way will be a negligible amount if that date isn't convenient.
But don't cancel anything with BT unless you're moving to a non-Openreach based provider.
Message 3 of 3
Re: Leaving BT
When I moved from BT 7 months ago I waited till the week my BT FTTC contract was due to end before I started the switch to another isp on FTTC.
I had been looking around at other isps a few weeks before that to see what other deals there was.
I was also moved to internet calls or digital calls as some call it for my landline calls when I moved isp but have not used landline for calls in well over the last year.
