Message 111 of 156
Re: My BT Problems
@pumagirl123  Thank you. I was slightly nervous that others might have been sceptical about what I’ve been stating.
Message 112 of 156
Re: My BT Problems
@Shelley224  I’m beginning to wonder if this is relative to the username aspect. When I was with BT, my username was always my email address. Of course there may be some one out there who can debunk that theory?
Message 113 of 156
Re: My BT Problems
Whilst I do have a bt email address via my moms home broadband account it is not linked to my own account which just as tnt sports on it as I used a non bt email address when creating my bt account
Message 114 of 156
Re: My BT Problems
@Kimberlin  I originally had a user name different to my email address but was prompted to change it to an email address that’s when the problems started
Message 115 of 156
Re: My BT Problems
@Kimberlin  For reference I’ve always had an email address has my username
Message 116 of 156
Re: My BT Problems
@Kimberlin There seems to be no identified link at the moment as to is and isn't having issues logging on. Even the BT technical team say the same.
It does not seem to be caused by anything that we as users are or are not doing. It is an issue originating from BT that has occurred to a large number (but not all) customers since they changed their login systems. They are currently scrabbling around trying to find a solution.
Message 117 of 156
Re: My BT Problems
@Shelley224
And what do you expect a moderator to do?
BT are aware of the problem some people are having and appear to be working on a fix.
Message 118 of 156
Re: My BT Problems
@Kimberlin ...must say it was convoluted and took some doing as you have to flit between the MyBT App, emails with BTID passcodes, back to the App and then Text passcodes for the 2 factor authentication, but once done you're in.
Message 119 of 156
Re: My BT Problems
@Kimberlin could be on to something regarding usernames. As far as I'm aware, usernames were mandated to be an email address a few years ago. Perhaps those having problems didn't do so.
Message 120 of 156
Re: My BT Problems
@licquorice  As I’ve stated previously my username has been an email address ever since I signed up in 2017 and I’m having issues logging in so it’s unlikely that is the route cause
