Message 21 of 24
Re: Moved from Fibre 1 to Fibre 2... but no difference
Without seeing the line stats it's impossible to tell what the problem is.
Message 22 of 24
And is there no way to do that with an Openreach modem?
Message 23 of 24
There is if it is an Huawei HG612. The unlocking is fairly trivial if you wish to unlock it.
https://kitz.co.uk/routers/hg612unlock.htm
Message 24 of 24
@Bungaroosh wrote:
@RobbieMac helped with this previously.
Robbie, I wonder if you can tell what is going on? Is this really just down to an old (but functioning) modem and hub?
Many thanks.
Thanks for posting back @Bungaroosh
Sorry that you seem to be experiencing this same issue again.  We'll be happy to see what's going on.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
