Message 1 of 2
Netflix Standard / Premium Add-on Not on BT Site
Noticed recently (and mentioned to lady last week when re-contracting, just for info) that if you go through the BT website via this route "Broadband" > "BT Broadband deals" then based on your address pick a broadband package and "Customise package" - if you add a TV package there is no option at all to upgrade from the Basic Netflix with ad's tier anywhere .... I'm damn sure there used to be?
However if going via "Broadband" > "EE broadband deals"  OR "TV" > "TV and broadband deals" you do get the option via either of those two routes to change / upgrade from the basic Netflix plan once you've added a TV package... as indeed you also do if going direct from the EE website.
Just thought I'd mention it.
1 REPLY 1
Message 2 of 2
Re: Netflix Standard / Premium Add-on Not on BT Site
This is a community forum - no one from BT will see it.  You will have the option to change your Netflix package from your TV box once you are all set up - hope this helps.
