Message 1 of 8
No Broadband Connection (7 days after activation)
I recently moved into a new house and ordered a BT Broadband package for my Internet usage as I work from home. My HUB was set up long before my activation date (29th June) yet I still have no Internet connection.
I reported a fault on the day of activation and it remains open, still unfixed. I continuously get emails and texts letting me know 'it's up and running' and to get in contact if there are any more issues. Everytime I get in contact with support, they assure me my issue will be fixed with the 'highest priority' yet nothing has changed. I have asked multiple times for an engineer to come out and investigate if there are any issues with any interior wiring, yet I'm never given a clear response whether one will come.
I don't understand where the problem lies. All my HUB wiring is correctly fitted, I have reset it multiple times yet I still can't get a connection. This is becoming very stressful for me and I'm unable to work whilst it remains like this. Any thoughts or guidance?
7 REPLIES 7
Message 2 of 8
Re: No Broadband Connection (7 days after activation)
are you trying to get FTTP (fibre to your home) or FTTC ( still using master socket)  when you connect hub what colour is light
Message 3 of 8
Hi, I believe it's FTTC as I have the grey broadband lead plugged from my router to my dual master socket. It blinks orange when it's on and has done so for the last 7 days.
Message 4 of 8
If FTTC and using master socket have you checked that you have a dial tone
Message 5 of 8
We don't use a landline so we just went for a broadband only package. Can't check the landline unfortunately
Message 6 of 8
Is this issue resolved. If not, rattle of an e-mail to the CEO, ******* (no spaces) and it will be forwarded to the executive complaints department.
[MOD EDIT - removed email address]
Message 7 of 8
you need to remove the email address as not permitted to post on forum.  you did this before and it was removed by mods
Message 8 of 8
@Quesada you are replying to a 3 year old thread!
