Message 1 of 10
Re: delete account from My BT
Hi David,
Could you, please, do the same for me?
I have 2 old accounts and it seems bt.com has a bug, where an online order (upgrade) assumes the first account in lexicographical order, which is almost always not the last one. Long story short I cannot upgrade online, once I move to checkout it renders “BT ID is not recognised”.
Alex
9 REPLIES 9
Message 2 of 10
Hi @sampai and welcome to our community.
Thanks for posting. I can get the old accounts removed for you. Check your inbox for my message and drop me over a reply with the details.
Cheers
David
Message 3 of 10
Hi @sampai, thanks for taking the time to speak with me yesterday. I can see you've set up the BTID again now and that the old accounts are no longer linked to your BTID.
Cheers
John
Message 4 of 10
Hi John,
All good, many thanks!
Alex
Message 5 of 10
Re: Delete account from My BT
I have an active account and an inactive account attached to my BT ID.
On login the system defaults to the inactive one so an account details cannot be found error is shown, and try back later.
I'm not thrown out of My BT so moving to Your Details or Your Account I can see the active account number and billing but nothing else. Attempting to see Your Products or Your Halo defaults again to the inactive account / no details error
I can't upgrade, change Halo or migrate to EE
Over last month mutiple prolonged webchats with advisors, two recent more helpful ones via phone, often involving deleting or renaming BTID then setting up a new one with a new email, then original email then wait 24 hours all with no joy, inactive account is still there causing problems
As account holder for both can I not delete the one I dont want ?
Message 6 of 10
@RetiredOldDad
try contacting billing using message now and they should help
https://www.bt.com/help/contact-bt/account-and-billing/broadband
Message 7 of 10
Hi there, did you get this resolved?  I have the same issue and have wasted hours with BT guides who can't get rid of the inactive account.  On the verge of leaving BT after 25 years as a result.
Message 8 of 10
Hi David, are you still able to help with this issue?  I have the same problem with an inactive account to which the MyBT login defaults and I can't access any of my BT services.   Hours online with guides who can't fix it, I was told my BT ID had been deleted and reinstated but the problem is still there.   Grateful if you can help as I am on the verge of dumping BT after 25 years.  Thanks if you can, Mary.
Message 9 of 10
The mods have changed and they no longer have account access so you either phone CS 03301234150 or try billing message now
Message 10 of 10
Thanks, have tried both already, several hours of exchanges, multiple repetition of issues, no resolution. I can see others have had this problem going back a couple of years now. I did get a BT guide to delete my BT ID and re-instate it on Saturday, didn't make any difference. The inactive account is still there. Seems my email is linked to that account. There is an instruction to create a BT ID via the email page, but I get the message 'that address is already registered'. I know! It's registered to my BT service account!
