Message 11 of 21
Re: Openreach do not have my address
thank you so much i need broadband for work
Message 12 of 21
Bear in mind, it can take 10 days for it to be updated, so it would be worth considering a 4G mobile broadband connection while you wait.
Once a broadband order is active, and if there is likely to be a delay, you can ask BT to loan you a 4G mini hub, while you wait.
Message 13 of 21
yes i have that but its not very good it keeps cutting out
Message 14 of 21
@Pebblecottage
While you are waiting.
Use the address checker for your address, on the link below, and post the results, but edit out your address details first.
Message 15 of 21
Hi @Pebblecottage
Thanks for posing, sorry to see you've had this experience when trying to get service.
I've sent you a private message asking for more details so we can try to assist you with this.
Stuart
Message 16 of 21
thanks for this but i dont have a phone line what are the other two please?
Message 17 of 21
@Pebblecottage
Look at the top line where it says "Address Checker", and select that option instead.
Do not forget to respond privately, to the private message from @StuartH
Message 18 of 21
sorry worked it out and my address is not there but as i said it is on Royal mail
Message 19 of 21
yep i sent a private message back to stuart
Message 20 of 21
That is fine, you will have to wait for the update. Its just odd if there was a phone there before, but it may have been with a provider that does not use the Openreach network, or the routing information has been lost by Openreach.
Hopefully @StuartH  will get it sorted for you.
