Message 11 of 13
Re: Openreach rejecting orders :(
Internet capture.PNGAttaching the screenshot from the broadband checker:
Message 12 of 13
thank you @plazo. will try it out..
Message 13 of 13
Hi @aniriansha. Did you get to the bottom of this issue in the end?
I'm having the exact same problem at a property I moved into last month. I have now had 6 rejected/cancelled orders with 3 different providers. None of which have been able to give me a clear reason as to what's going on. And I'm getting a lot of conflicting information.
Be great to know whether you managed to get broadband sorted in the end?!
