Message 11 of 16
Re: Possible wrong install?
Hi
Yes I am connected to an ont box on the wall which was installed by city fibre 2 years ago.
I am on the 500/500 profile with zen which will end on the 20th.
I will then join bt on the 23rd.
I thought because I signed upto fibre essentials I would get a fttc install
But because I have a fttp connection,  bt essentials will use this to give me the 40/10 speeds I signed up for?
Anonymous
Not applicable
Message 12 of 16
OK, so now it's clear.
Presumably when you signed up for FTP with Zen, City Fibre were  the only provider. Since then Openreach have also installed FTTP. BT only use the Openreach network, they can't use your existing connection. That's why you've been given a date for a fresh install of an Openreach FTTP connection.
Message 13 of 16
But with the 40/10 speeds I've been quoted?
Message 14 of 16
@Mark_1976
FTTP can support any speed, up to the maximum. You will get what is quoted on your order.
Anonymous
Not applicable
Message 15 of 16
See messages 2, 3 & 4...
Message 16 of 16
Thanks to everyone who replied I do appreciate it, I hope you all enjoy the rest of the day.
Many thanks.
