Message 1 of 7
Problem logging into MyBT
Hi
Every time I try to log into MyBT it takes me to my BT email inbox. If I try to navigate to MyBT it takes me back to the log-in page and then back to emails again. Please can you help to stop this happening?
Pat
6 REPLIES 6
Message 2 of 7
Re: Problem logging into MyBT
Hi, @PatMoore123 welcome to the community and thanks for posting. That would indicate you're logging in with a BT email address that has not been set up as a BT ID. Would you have used a different email address to set up your MyBT account previously?
Neil
Message 3 of 7
Hi Neil, thanks for getting back to me. I've just tried an old "freeserve" email address as a login but BT are telling me they do not recognise it. So I don't think there's another email address set up as a BT ID.
Pat
Message 4 of 7
@PatMoore123 Thanks for trying that, have you ever set up a BT ID before? If you've been a customer for a long time it's possible to have a BT email address but have never set up a  BT ID.
If you follow the create a BT ID process does that work?
Neil
Message 5 of 7
Hi Neil, I have setup a BT ID and the website now opens but it does not link to my account. I have tried adding the account multiple times without success. It says that it is added and will take 5mins to update but it is still not there. Do you have any suggestions to resolve this problem please?
Pat
Message 6 of 7
Hi @PatMoore123, thanks for doing that and sorry you can't get the account to link to the BTID.
I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help you get this fixed.
Cheers
John
Message 7 of 7
Thanks for sending over the details @PatMoore123 .
I'm glad I was able to get this sorted for you.
All the best
David
