Message 1 of 6
Claiming Reward Card Not Working
Hi,
I signed up for BT Broadband and was meant to be able to redeem a reward card.
However, when attempting to load the account with the reward on it I just get served a blank strip between the top and bottom site navigations.
I've tried in different browsers but I still can't access the reward card.
Is anyone able to help?
Rich
5 REPLIES 5
Message 2 of 6
Re: Claiming Reward Card Not Working
when was your activation day for broadband?
Message 3 of 6
@NeilO I've seen you help a few people out with this issue, are you aware of a fix I could try?
Message 4 of 6
Hi @RickySwitch, have you set up your BTID? What is a BT ID and how can I get one? | BT Help
If you've already done this is there more than one account linked to this BTID?
Cheers
John
Message 5 of 6
Hi John,
Yes I have the account ID and have multiple accounts on there, but it's when I try and select the rewards from the correct account that I don't manage to see the page as it just goes blank.
Rich
Message 6 of 6
Hi @RickySwitch and thanks for the reply.
I'm sure the multiple accounts is were the problem is. I can sort this out for you. Check your inbox for my message and drop me a reply with the details.
Cheers
David
