Message 21 of 42
Re: Broadband takeover without my consent
OTS is a brand new system, designed to let customers swap between providers on different networks, not just the Openreach system.
There are a few issues that have turned up, this being one of them. All of the incentive is with the gaining CP, the losing CP has little control over the move and no way to stop it once it’s set in motion.
Someone put the wrong address in, that’s human error, the rest is all electronic with no human involvement.
Message 22 of 42
So I as the person who’s service this affects has to unpick someone else’s mess. I can’t just say “no this want me” and it stop.
Utility Warehouses lack of help or willingness to deal with me is as much the issue here as the process.
Message 23 of 42
Not hell bent on anything , if you called the appropriate BT number 08000851756 , (presumably the correct number if it were on the BT email )  , then it’s unclear why the cancellation wasn’t straight forward, and the cancellation not put in place immediately.
Both  the OTS and NOTS system before it don’t require anything other than the new ISP to start the ball rolling , the consumer doesn’t need to contact the old provider themselves, that’s the entire point from the regulator point of view , if the customer has decided to switch they don’t want the old provider having the option to dissuade the consumer from switching…this obviously opens the system to mistakes as in your case , misidentifying your address for the customer that called address, and abuse , like slamming or even malicious actors looking to cause disruption.
I’ve never defended what’s happened , I queried if the correct process to cancel was followed , as often a customer doesn’t follow the instructions to cancel the migration correctly , but if you did follow the correct procedure to cancel the change , and that wasn’t actioned that’s an error on BT ‘s part .
…but to the main point , why is it that easy for a ISP to start migrating a customer without consent, that’s because Ofcom want it like that , their view is the ease to switch , having to only contact a new provider, outweighs the problem of slamming or misidentification of a customer address, before OTS and NOTS , the process was you called your old provider, asked for a MAC ( migration authorisation code ) , you gave this to the new ISP , this system had inbuilt checks ( a call to both the old and new provider was necessary being the main one  ) Ofcom got rid of that .
Message 24 of 42
as you are not a customer of Utility Warehouse why would they provide you with any information on another persons application for connection
As I said previously if it was your neighbour who was looking at possible changes but never placed an order than I can't understand why any of this takeover has happened
Message 25 of 42
I really appreciate all the replies and you guys taking the time to explain, however, the whole thing seems to be half-baked and BT seems to not be following the correct process as I know that I called the number on the email and the person that is now having the same issue did the same, and they seem to not have a proper system in place to deal with such things as that is what I meant when no lesson was learned since this keeps happening
Message 26 of 42
@davidmbell  Have you taken up the offer made by mod @Christopher_G  earlier in the thread? If not, I suggest you do so.
Message 27 of 42
I did and we’ve message one another thank you.
Message 28 of 42
@davidmbell - If you took up the offer of the £4 savings, I feel pretty certain this would count as a re-contract and therefore another 18 months.
Don't forget, the prices increase on 1st April (all fool's day) although BT say 31st March!
Message 29 of 42
The guy I spoke to today said that recontract hasn’t gone ahead due to the request to leave. He said it should now be in place, as things are now stopping, not holding my breath.
Message 30 of 42
This from Ofcom explains how OTS “should” work, with the Losing Provder and Gaining Provider.
It just doesn’t factor in my scenario, where my address has been incorrectly entered by someone (who’s also a BT customer).
https://www.ofcom.org.uk/siteassets/resources/documents/consultations/category-2-6-weeks/211987-simp...
Why ain’t there any sort of cross check over the persons details who’s setting up the new provider and their email? Or phone number?
