Message 1 of 4
Re: Cancel BT Contract - my Father moved into a Care Home
Hi. I have the same issue. My parents have moved into a Care Home and I need to cancel their BT contract. As per the original poster I have LPA. Appreciate your advise
regards
Mike
3 REPLIES 3
Message 2 of 4
I moved your post to start your own as previous was marked as solved
I have asked forum mods to help you and they will post here
Message 3 of 4
Hi @MikeM2024,
I'd like to help you fully with this. I'm going to send you a private message so we can talk.
It will take about 5 working days before we can get back to you but we will do all we can to get this sorted.
Thanks for flagging this to me @imjolly
DanielS
Message 4 of 4
Thanks for sending over the details @MikeM2024
I'm glad I was able to get this sorted for you.
All the best
David
