Message 1 of 4
Re: Legal Name Change - Transgender
Hi there, sorry to jump into this thread. I'm in the exact situation as the original poster and was wondering if I could get assistance to update my details?
3 REPLIES 3
Message 2 of 4
Hi Cat_M
Welcome to the Community.
There is a process in place for this now to make this much simpler and remove the stress.
If you call us on 03301234150 and select billing this should be a straightforward call. If you try this and have any issues please post back and I don't foresee a problem. We're experiencing unusually high volumes and this might be a quicker solution for you, but please come back to me should you need to.
Stuart
Message 3 of 4
Thanks for the advice, the member of staff who assisted me was so good. Was able to get everything changed in 5 mins
Message 4 of 4
Hi @Cat_M
Thanks for posting back, brilliant glad you got this resolved so easily 🙂
Stuart
