Message 1 of 2
Remove a Phone from My BT
Hi  I'm signed into mybt and it shows two mobile phones.  This was correct, however one of the phones is no longer in use but I am still getting billed for it.  I have looked all over /mybt and cannot see a way to remove it.  Is there any way I can do this from /mybt or do I have to phone up?
1 REPLY 1
Message 2 of 2
Re: Remove a Phone from My BT
you need to phone CS 03301234150 and they will help  if still getting billed are you still in a contract with that phone?
