Message 1 of 3
Remove multiple BT accounts from ID
Hi I have a number of BT accounts on my address. Can someone please tell me how I can remove the inactive ones and keep just one BT ID email address.
2 REPLIES 2
Message 2 of 3
Re: Remove multiple BT accounts from ID
Hi @Patel236 and welcome to our community.
Thanks for posting about your BTiD. There's a couple of options we can look at here so I'll drop you over a private message now. Just send me over a reply and I'll look into it.
Cheers
David
Message 3 of 3
Thanks for sending over the details @Patel236 .
That's all been sorted for you now. Post back if you have any other problems.
Cheers
David
