Message 1 of 5
Return equipments
Hi, I just check how's my returns, it shows "awaiting returns", I send the equipments 29/04/2022,.
also I check royal mail status, it shows the items was delivered 1/05/2022, 11 days ago...
Anyone can help what's goin on?
Thank you.
4 REPLIES 4
Message 2 of 5
Re: Return equipments
It is presently taking three to four weeks for accounts to be updated.
If you call BT 0800.800.150 with your Proof of Postage they should be able to update your account for you.
Message 3 of 5
Hi @joseluismartin769,
Thank you for posting. It normally takes around 3 - 4 weeks for the equipment to be marked as returned once it's been sent back to BT.
If you ring the number as suggested @gg30340, they'll be able to mark that as returned right away.
Alternatively, I can also do this for you, if you send me your details.
I have sent you a private message with instructions on how to contact the team.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
Thanks,
Paddy
Message 4 of 5
Hi PaddyB, thanks for reply.
I just send a private message
Message 5 of 5
Thank you for sending in your details and including the proof of postage.
I've marked the equipment as having been returned and this will stop any follow-up.
Thanks,
Paddy
