Message 11 of 19
Re: Simple Phone Only Order - too many options and upselling
I would be extremely surprised if BT will supply a landline only via FTTP, it would be economic madness for them to utilise a slot on the PON for just voice, let alone having to supply an ONT and Hub2 as well.
Message 12 of 19
This sounds more like business usage and not residential?
Message 13 of 19
 what's the difference nowadays ?
Message 14 of 19
What's the difference between what?
Message 15 of 19
business and residential use - most houses nowadays have someone working from home, using their landlines for business usage.
Message 16 of 19
Its totally different, BT Business use Cloud Voice, where calls are dealt with centrally, and can be diverted to either IP phones, or a special application on a mobile.
Calls are still carried over the IP network, but its a true VOIP solution without any analogue presentation, unless a special ATA adapter is purchased.
https://business.bt.com/products/voice-collab/digital-voice/cloud-voice/
Its more suited for business usage, whereas the residential service is not intended for business use.
Message 17 of 19
Hi @_steve   If you have reliable 5G broadband then have you considered a VOIP service. I changed my BT landline number to Voipfone and have never looked back. Many more features like voicemail instantly delivered by email etc.
Message 18 of 19
As BT have a telephone USO , and the address already has FTTP fitted, then it’s not going to be debatable if BT can not choose not to supply telephony , the only issue is how the ‘landline’  telephony will be supplied in an all IP world, using the existing FTTP network is now the default network , it doesn’t affect the availability of FTTP for others as capacity is provided for all addresses.
As the OP states the idea is to divert incoming calls to the landline number ,to one of a couple of mobile numbers  ,  bearing in mind as a new landline customer,  the new landline number will  have no history or association with the OP yet ,  wanting a landline seems even stranger , if the OP already had a landline number that was widely known, or had various ‘adverts’ quoting a landline number  , or have a client list and those clients use a particular already known landline number , that’s one thing , but obviously even the OP won’t know yet , what landline number that will eventually be allocated to the landline ,
It seems strange, who is going to call this yet to be allocated landline number , why wouldn’t who ever is going to call the landline  simply be asked to call the mobile number instead  ?
Message 19 of 19
@_steve
The BT Residential T&Cs forbid the use of the service for any trade, business or profession.  Apart from that, I would not consider a residential service reliable enough for business usage, especially with BT Digital Voice and some of its reported  issues.
