Message 1 of 6
Special Services
Hi, does anyone know what special services tel no. 03004563569 Is used for? My landline has dialled it 8 times in Feb in 2 days. I’ve tried ringing it and it’s just electronic noise.
5 REPLIES 5
Message 2 of 6
Re: Special Services
@Cerith101
Do you have a care alarm or some other alarm system connected to your phone line?
Message 3 of 6
Yes I do, is it that?
Message 4 of 6
https://who-called.co.uk/Number/03004563565#user-reviews
Not sure how outgoing calls would be generated though.
Edit
Ignore, Google throwing up a bum result. As @Keith_Beddoe suggested.
Message 5 of 6
That would be the reason, those units normally make test calls to the  alarm monitoring centre, to check that they are working. Its normally only a small charge.
If the alarm is pressed, then that of course would generate a call.
Message 6 of 6
@Cerith101 I called it there and got the same electronic noise and I would agree with @Keith_Beddoe that it's very likely to be your alarm calling the monitoring centre.
Neil
