Message 1 of 6
Stay fast guarantee
I am in the process of changing to fibre 2.  Within the contract I have been quoted a stay fast guarantee of 34Mbps whereas on the BT web site it states 62Mb (see below).  Does anyone know why there is a discrepancy?
I am also struggling to find a way of communicating with BT in writing.
Tags (1)
5 REPLIES 5
Message 2 of 6
Re: Stay fast guarantee
The minimum speed guarantee to a certain extent is irrelevant, the actual speed you get is almost entirely dependent on the distance you are from the cabinet, so assuming no defects on the line , the customer equipment and internal wiring etc , if the  line were capable of (for example) 70Mb , that what your line syncs at , irrespective if the MSG being 60Mb or 30Mb , it’s not like the speed is restricted to the MSG , it’s simply a threshold at which a problem can be investigated.
The only issue would be is if your line was delivering 70 and then developed a problem dropping the speed to 50 , with  a MSG of 30 , you may struggle to get a speed issue looked at by the provider as it’s still above the MSG , but if the MSG were 60, then 50 is obviously lower and triggers a response.
As far as the difference, if you had a line in service, it is generating real performance data , so the mathematical model /calculation of the line performance is superseded with real data  , if the user of that line were ( for arguments sake ) using their router on the end of a cheap extension cord and that was negatively impacting the performance  , or the line had an unreported problem that reduced the speed but it was unnoticeable ( so was never reported or fixed ) the MSG would be lowered reflecting the real data that indicates a slower sync rate , if that person stop using the defective extension, or the underlying fault repaired, the line speed improves and the MSG increases in line with the increased real world data.
Message 3 of 6
Thank you, however I am troubled by the contract stating 34Mb whereas the advertised is 62Mb.
Message 4 of 6
@Cappi
if you are changing (upgrading?) to fibre 2 what speed do you currently have?  the 62mb in the advertisement is an example for a customer getting a connection speed of 70mb+.  the lower your connection speed the lower stayfast guarantee
Message 5 of 6
142Mb
Message 6 of 6
142Mb , must be Gfast or FTTP , if you are FTTP then you get the headline speed , there is no distance related reduction , if you once could get Gfast , but it’s no longer a portfolio product , considering Gfast was only available to those with very short lines from the PCP , your FTTC speed should be pretty decent as you should be pretty close to the cabinet.
TBH , I don’t really see the issue , if you want FTTC , the speed you get is related to the distance you are from the cabinet, not the MSG , the NSG is only relevant with defective lines , the minimum speed guarantee makes no difference to that , your line is either OK or it isn’t .
If   won’t commit to taking FTTC because the MSG is significantly lower than the speed you almost certainly will get , rather than being around 10% lower than the sync speed , don’t purchase FTTC , it’s unclear what you are actually expecting .
