Message 1 of 5
TNT Sport with Broadband but wanting to remove TNT Sport
Hi
I have a broadband contract until 28 Mar 2025 but would like to remove the TNT Sports on Sky and TNT Sports HD.
Would I have to keep paying for these until the end of my Broadband contract or can these be removed with 30 days notice?
Amy help would be appreciated.
James
4 REPLIES 4
Message 2 of 5
Re: TNT Sport with Broadband but wanting to remove TNT Sport
do you pay BT for TNT sports on SKY?  if so are you not in a fixed term contract for your TNT sports and ending early will probably result in charges ?  check MYBT
Message 3 of 5
I have BT Broadband and have TNT Sport through BT but access it on Sky.
Message 4 of 5
@shreevejames
yes but you have a fixed term TNT sports contract with BT and terminating before end of contract period will incur charges hence checking MYBT to see when contract end date is for TNT
Message 5 of 5
IF The TNT Sports was taken as part of a package or as a promotion  it is likely  to have a fixed minimum  term. myBt should indicate when is that end date. The HD is likely  to be a rolling add on again MyBt should show this.
