Message 11 of 16
Re: Try move to EE
they have replaced 10 time does same thing
Message 12 of 16
Re: Try move to EE
Hi @UkzVortex
Thanks for your posts and welcome back!
I am sorry for the problems you're having placing your order.  Can you send us over your details so that we can fully investigate from here, please?  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Robbie
Message 13 of 16
Re: Try move to EE
if BT have replaced hub as you say then problem cannot be a faulty hub
Message 14 of 16
Re: Try move to EE
Yes it is the fault with hub over heating popping cracking
Message 15 of 16
Re: Try move to EE
I cannot believe that has happened with everyone of the 10 you say you have had as replacements
Message 16 of 16
Re: Try move to EE
@UkzVortex
The noise you hear from the home hubs is most likely from the voltage regulator inside which does generate high frequency noise which is normally inaudible to most people, but some can hear it, especially if they are under 40 years of age.
The noise can be modulated with what sounds like a popping noise, as the loading on the voltage regulator changes.
This does not mean its overheating, as if it was overheating, it would totally shut down and the lights would go off.
Its quite possible for all home hubs to produce this noise, so an EE hub is likely to do the same.
