Message 1 of 2
Unable to access MyBT
Hi
Today whilst on laptop printing out emails I though I would log into MyBT just to see the account details.  Only can see part of them but unable to log in and use password as per normal, its very bizarre.  I always log out of BT when on laptop as its not used that often.  So it looks like Im partly logged in but cannot do anything and can see a random password of numbers and letters which certainly are not mine prompting me to log in using them which I will not.
Viewing both email accounts are fine but logging in with passwords and use names.  On my mobile I just have the BT email app, nothing else.  Odd thing to say would it be worth getting the app on my mobile so I can view the account,
Hopefully its just a BT glitch,  any advice  would be helpful.  Also I will update you on this incase anyone else has this issue.
1 REPLY 1
Message 2 of 2
Re: Unable to access MyBT
Good morning @Mattiesmomma 😊
It's definitely worth giving the app a try to see if this is giving you the same sort of errors.
Have you had a chance to try a different browser, or logging in via a private browsing window, too?
Peter
