Message 11 of 42
Re: Unable to complain to BT about incomplete fibre broadband and phone
Further to my message a moment ago, I'm anxious too to contact the apparently even more elusive Open Reach. It should by now have installed its own power-supply cabling to the hub to replace my own
cable (working perfectly, of course.) If I had not had that cable and adapter on hand to lend, what would Open Reach have done?
Message 12 of 42
Is your hub connected to a white box like this and if so are lights green like this
Message 13 of 42
Hello,
I've repeatedly scoured the website but every time I've been directed to the 0330 1234 150 phone line. I have not been able find any other way of lodging a complaint. The link you provide takes me back to where I've been a dozen times before, unfortunately. If you know another way, I would be most appreciative.
Message 14 of 42
Thank you, Mr Beddoe.
I appreciate what you say. I'm still very unfamiliar with this "Community".
I was, however, under the (false?) impression that BT moderators monitored this discussion group and would take note and act. Perhaps tomorrow? Or perhaps I'll have to visit some BT premises in person!
Message 15 of 42
@Yxull3
It is the customer responsibility (ie you) to ensure there is power available to enable openreach to connect the ONT and the HUB.  Openreach will not be back with power cabling
Message 16 of 42
Thanks for your reply. Perhaps sending a photo will be necessary, although I'm so unfamiliar with this discussion group, I would not know how to do so.
However, to be perfectly clear, the Open Reach engineer told me she had finished the installation and the later email from BT that "everything had been done at their end" and that the system was ready to go, confirmed this. There are times when you have to trust the professionals.
Message 17 of 42
@Yxull3
I have already posted photo to help you so can you confirm openreach installed something like this and your hub is connected by cable
Anonymous
Not applicable
Message 18 of 42
Let's start at the beginning. Is the Internet working?
Message 19 of 42
Next, has your Digital Voice service been activated.
Go to the hub manager (put 192.168.1.254 in your browser address bar)
Does it show your phone number or does it say 'Not Configured'
Message 20 of 42
It's not clear if you have full fibre FTTP or simply FTTC
Do you have an Openreach ONT like the picture posted by @imjolly
