Message 1 of 4
Upgrade contract
Query about the free Xbox pass.
If I renew my package I can upgrade from a download speed of 67Mb to 500Mb for effectively an extra £1 per month (There is a 'FREE' £75 card)
The Xbox pass also comes as a free add on, then £12 from month 6. If I do not activate this I presume I will NOT be charged from month 6. BT terms and conditions do not make it clear. Thank you!
3 REPLIES 3
Message 2 of 4
Re: Upgrade contract
Even if you activated the Xbox pass for 6 months you can cancel before 6 months up and you will not be charged after end of 6 months
Message 3 of 4
"If I do not activate this I presume I will NOT be charged from month 6"
Correct.
Message 4 of 4
Thank you for a swift reply!
