Message 1 of 10
What can I actually get in my home?
Hi all
I've been checking the Broadband Availability Checker on the BT Wholesale website and getting some contrasting information.
My exchange is DOUGLAS (Glasgow City Centre).
As you can see from the table, FTTP on Demand is listed as available but at the bottom notes, it says not available?
Also, I've had speed issues before because I am too far from the exchange. I've been told the max speed I can get is what I currently have which is 140mbps.
I've also been in touch with Openreach direct who have advised me that GFast is available to me at over 300mbps...
Just a tad confused about what I can actually get because I'm being told one thing and another.
My broadband is due for renewal mid-October and although CityFibre have been digging up the whole of Glasgow for the last year, including on my street, apparently I still can't get 1000mbps fibre broadband yet.
Not sure what to do in terms of renewal.
Cheers
DP
9 REPLIES 9
Message 2 of 10
Re: What can I actually get in my home?
from dslchecker it appears you can get Fibre 2 80/20 or G.Fast up to 300mb.  there is no FTTP available to you currently
Message 3 of 10
thanks for that - would you know how I would go about getting the GFast up to 300mb? it doesn't appear to be an option when I go to renew my broadband
Message 4 of 10
Hi @deadpool from the max observed speeds yesterday it shows you're already on G.Fast with a download speed of 194Mbps.
Neil
Message 5 of 10
Hi Neil
Good to hear from you again 🙂
Thanks for checking this but I'm not sure where that figure is coming from? Not once in all my time with BT in my property have I seen a speed of 194mb.
It tops out at 140mb.
Message 6 of 10
@deadpool it's under the observed speeds section on the Availability checker results you posted. The last recorded speed was yesterday under the G.Fast section.
If you log in to MyBT and click your products what's the name of the broadband package you have?
Neil
Message 7 of 10
Hmm that is strange. I'm not denying what it is saying but I am doubting it. I'd be more than happy with 194mb but I promise you it's never hit over 140mb. I've speed-tested it on several devices for the last 2 years and that's been the max.
Even when the engineer tried to sort things at the exchange he said 140mb would be the max.
The broadband package is called Fibre 100 with BT Halo 3
Message 8 of 10
@deadpool Fibre 100 is capped at a maximum 160 download. Is it showing Fibre 300 available in your offers section?
Neil
Message 9 of 10
That makes sense.
The highest in my offers section is Fibre 250 (177mb)
Message 10 of 10
@deadpool That would remove the 160Mb limit that's currently on your Fibre 100 plan.
