Message 1 of 10
Cannot Access MyBT - login takes me straight to email
Have tried logging in with my BT ID, but it still goes back to EMail. Possibly as my BT ID used to be, I believe, one of my email addresses. How do I cure this!
Thanks, Tim
9 REPLIES 9
Message 2 of 10
Re: Cannot Access MyBT - login takes me straight to email
Hi @TimGlass, welcome to the forum and thanks for posting.
Have you been able to access your BTID ok until recently?
Are you sure that the email address is the one actually used for the BTID as it doesn't have to be a @btinternet email address?
Cheers
John
Message 3 of 10
Thanks. I can't remember it not working ever before - I use it to check my bill, inter alia.
I do have another email address that's not btinternet, but this seems to take me to my bt email as well!
Do I need a new BTID, and if so, is there an easy way to do this.
Many thanks for your help
Message 4 of 10
Thanks for posting back @TimGlass
Can I just confirm you're trying to log in >> here << ?
Thanks,
Robbie
Message 5 of 10
Yes, that's where I'm trying to log in
Thanks, Tim
Message 6 of 10
Many thanks for confirming that @TimGlass
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 7 of 10
Thank you.
I sent what I could last Wednesday - just awaiting reply
Tim
Message 8 of 10
Hi @TimGlass,
I'm sorry for the delay in team replying. We are working through a bit of a backlog at the moment. I've check our queue and we do have your details. One of the team will be in touch as soon as we can.
Thanks,
Paddy
Message 9 of 10
@TimGlass Thanks for speaking with me this morning, I was happy to help you get access to your MyBT account.
Neil
Message 10 of 10
Thanks Neil,
Explained well, and solved at first attempt. Very useful, and very helpful!
Tim
