Message 1 of 11
landline provider
I'm moving to a property that has a talktalk provided landline & broadband, but the bt wholesale checker isnt recognizing the phone number.
I know its a bt dsl checker but I sorta assumed it was effectively an openreach checker and hence a landline would be more accurate than an address potentially.
any advice?  Im trying to figure out the potential for fibre broadband, thats all.
thanks in advance.
10 REPLIES 10
Message 2 of 11
Re: landline provider
@whynotask
Use the address checker for your new address, on the link below, and post the results, but edit out your address details first.
Message 3 of 11
Hi, @whynotask They have their own exchange equipment so BT Wholesale is not involved in the provision of the service, hence no results when using the number.
Neil
Message 4 of 11
Thank you. I have checked this, and shared results on my other thread. All ISPs have told me very slow speeds available, and the dsl checker shows unavailable/waiting list for FTTC and SOGEA respectively. Likely a cabinet full issue.
Message 5 of 11
oh right, thanks @NeilO. Is there a tool to search the Talktalk exchange ?
Message 6 of 11
@whynotask
There is no separate checker, as Talk Talk still use Openreach.
Message 7 of 11
As you have been told, there is no spare capacity on the Openreach cabinet.
Message 8 of 11
To what purpose? The cabinet is full you are flogging a dead horse.
Anonymous
Not applicable
Message 9 of 11
@whynotask
What's the plan, keep starting new threads until you get a different answer?
Message 10 of 11
Appreciate everyone's help.
Only started a 2nd thread to understand how to check databases using a phone number, not about the original address checker.
Have learnt that talk talk phone numbers don't show up on bt's dsl checker.
