Message 11 of 16
Re: "Silver" address issue - how to upgrade?
thanks
do u have the phone number
it is really annoying and bizzare you would have thought any survey would have picked up the cable & supply on our site
Message 12 of 16
@teddy2025 answer was from Keith in this thread.
If you are sure its FTTP, then give the FTTP helpdesk a call on 0800 587 4787and see what they say. They should be able to update any routing info.
Message 13 of 16
thanks
managed to speak to them and got it sorted
cheers
Message 14 of 16
Thanks for coming back and letting everyone know you have for this sorted @teddy2025
Have a great week 🙂
Leanne.
Message 15 of 16
I have a similar issue whereby my address is silver listed because we changed the name of the house 20 years ago and OpenReach haven’t updated their database. My ISP says that they cannot contact OpenReach to ask them to do it. Is there anyway I can/ anything I can do or am I stuck with my current provider until full fibre is provisioned? Which might not be for a couple of years yet!
Message 16 of 16
@filpa
Only your current ISP can contact Openreach.
This forum is for BT customers only.
Try posting on your ISPs forum, or wait until you are out of contract, then try with a new provider, like BT.
