Message 1 of 9
yes a beginner! Bots!!!!
I have been unable to activate my BT ID and keep getting a Technical Issue message. I have been trying to do this for weeks now .  I have not been able to speak to a person and keep getting Bot text messages. I have been going around in circles and now I have an issue with Netflix and cannot access my account to see what the problem is. aghhhhh! Why did I leave Sky!!!!
8 REPLIES 8
Message 2 of 9
Re: yes a beginner! Bots!!!!
The old hands on this forum are very good.  If you post a bit more detail about the technical problem, they may be a able suggest a fix.
Anonymous
Not applicable
Message 3 of 9
Re: I very much regret leaving sky. BT help is useless
And?
Message 4 of 9
try using message now and see if billing can help you
https://www.bt.com/help/contact-bt/account-and-billing/broadband
Message 5 of 9
on line help
Finally found my way to an online help chat with a person who is trying to sort out my problem. I have been categorised as urgent. Fingers crossed!!
Message 6 of 9
Thank you. I would give a thumbs up but cant figure out how!
Message 7 of 9
@JNClarke
you can't on this forum board  I have moved posts to correct board
Message 8 of 9
I have had a lot of help from Sudipta via on line help messaging and now have a BT id. Thank you every one for help and suggestions
Message 9 of 9
Re: on line help
Morning @JNClarke
Thanks for coming back to the community and letting us know you have a BT ID set up after chatting with Sudipta.
Have a lovely weekend 🙂
Leanne.
