Message 1 of 5
BT Anti Virus Switched from Norton
Just tried to load virus protect on a second device and its switched back to MCAfee from Norton. Should I switch the device that is currently running Norton to MCAfee?
Secondly, I cannot install MCAfee anyway as the download link appears off screen and there is no scroll option to make it appear. If you click the blue box it just disappears.
4 REPLIES 4
Message 2 of 5
Re: BT Anti Virus Switched from Norton
Hi @GarySC, sorry you're having a problem with the virus protect.
Are your devices running Android and if so running on 8.0 or a later version?
Cheers
John
Message 3 of 5
Hi John
I have BT Virus Protect (Norton Antivirus)  on a Windows 10 desktop. This is all OK.
Have just acquired a Windows 11 Desktop which did have Norton installed but the licence has expired. I click the link to ‘Fix’ with the intention of using another of my 15 licences available but it tries to install McAFee.
Message 4 of 5
Hi @GarySC, thanks for getting back to me. I've sent you a Private Message so you can get in touch with the Mod team for help with this.
Cheers
John
Message 5 of 5
@JohnC2
Thanks for your inut.
I have found a solution.
Norton was installed on the W11 desktop but was flagged as ‘Licence Expired’ with a ‘Fix’ link. Clicking that link loaded a McAfee page for some reason but then I was unable to acess the .exe to download.
Instead, I logged into ‘MyBT’ on the new computer and was able to install a fresh version of Norton from the Security page. That looks as though it has worked.
