Message 1 of 39
BT App will not stay linked to account
When I try and open the BT App it tells me there is no account linked. I go through the steps to link my account but next time I open the app the same thing happens. Am I doing anything wrong or does the app have a fault?
38 REPLIES 38
Message 2 of 39
Re: BT App will not stay linked to account
I would try to make sure the app is up to date or failing that un install and re install the app.  If you are still having issues I would contact BTs technical team who will fit it.
Fix broadband | BT Help
Message 3 of 39
Hi @Alan_in_Hemel   just checking is it My BT App that this is occurring on ?  There seems to have been quite a few issues with that app lately. I believe you will need support to  investigate and correct.  I don’t believe it is a technical fault so not sure that the suggested link is the most appropriate .
Message 4 of 39
I have tried  deleting and re-installing the BT App on both my iPhone and iPad but the problem remains when I next try to use it.
Message 5 of 39
Hi @Alan_in_Hemel
Are you able to access all of your information through the My BT desktop site? Is the account all linked correctly there?
Chris
Message 6 of 39
Yes and when I link my account on the app all my information loads correctly.  However the next time I open the app the link to my account has disconnected and I have to start again.
Message 7 of 39
Are both of the devices you have the My BT app on completely up to date on their individual device software, @Alan_in_Hemel?
When you go into the app store and search for the My BT app, does it say 'update' next to it?
Chris
Message 8 of 39
Apps on both devices are up to date.
Message 9 of 39
Is the device software on both devices up to date, @Alan_in_Hemel?
Chris
Message 10 of 39
iOS 18.3.1 and shows as up to date.
