Message 1 of 12
BT Cloud Download not working
Hi, I am trying to download my files from BT cloud. I've installed the BT app on my desktop, but this does not allow any sync. I've also tried using the browser but eventually times out...
504 Gateway Time-out
HELP!!!
11 REPLIES 11
Message 2 of 12
Re: BT Cloud Download not working
Good morning @fmd001, welcome to the BT Community!
Just to be sure first of all, is if the latest version of BT Cloud that you're using at the moment?
You can download this here, and you should be running version 24.4.24.
If that's all up to date, can you please let us know what happens when you try to download through the app?
Peter
Message 3 of 12
Hi @Peter_W , I am having the same problem. How can I download to an external hard drive through the app please? I can't see how to change the destination. Thanks
Message 4 of 12
Hey there @Leonburgler.
I've had a check here, and when you select the option to download your files in the app for Windows, you should be able to select the external hard drive as the download destination.
You can only pick one location at a time though, so if you want to download to different places you'd need to do this separately.
You can find more details on this here:
Download your files from BT Cloud | BT Help
Peter
Message 5 of 12
Cheers @Peter_W , I'll give it another go. When I click 'Download' the app appears to close, is this normal?
Message 6 of 12
@Leonburgler I believe the app will minimise once the download starts.
When you navigate back to the app you should then see the progress of the download 😊
Peter
Message 7 of 12
@Peter_W it doesn't minimise, it disappears completely and when I open it again I can't see any activity
Message 8 of 12
@Leonburgler When you select to download the file and this closes, are you able to alt+tab back to the app running, or see it active in your task manager?
Peter
Message 9 of 12
@Peter_W Alt+TAb doesn't show the app at all.
I am getting notifications in the app saying "You've run out of space in the local disk C:\ and we cannot continue" however the destination folder is in an external hard drive. This is a new 1TB SSD so I don't know why it's trying to download to the C drive
Message 10 of 12
Thanks for checking that out for me @Leonburgler.
I'm going to pop you over a Private message so we can take a closer look into this.
Peter 😊
