Message 1 of 3
BT Cloud Storage
Good Afternoon
I have decided to leave BT with my change over happening in just under two weeks time.
I have received a letter from BT telling me what I will loose when I leave with one item being Cloud Stoarge.
I have never used BT Cloud Storage but I thought I would check anyway to see if anything was stored there. I have checked everything, photos, documents etc. and all are showing as no data. Every single folder states there is nothing in it.
The actual storage I have access too is 200GB. It states I am using 1KB of that storage and yet as above every folder has no data in it.
I know 1KB is minimal but how do I find out what is using up this amount of storage?
2 REPLIES 2
Message 2 of 3
Re: BT Cloud Storage
The empty folders will account for your 1KB of data. Delete all the folders and empty the trash then forget about it.
Message 3 of 3
The folders were created by BT and not myself. There is no option to delete them. As they are all empty I will leave them alone.
