Message 1 of 2
Norton Security via BT
I have paid for a Norton subscription for several years. It is due for renewal next month but it seems I should really take advantage of it being included with my BT package now. I have cancelled the auto renew accordingly.
My instinct tells me this is unlikely to be a smooth transition. Has anyone gone through this process and could point me towards any helpful advice as to how to best go about this? I assume the BT version will not have the VPN and maybe certain other functions. Can anyone advise exactly what product is provided please?
1 REPLY 1
Message 2 of 2
Re: Norton Security via BT
See links
Important updates to your virus and password prote... - BT Community
Solved: Re: Norton - BT Community
There are many more posts to view about Norton if you use the search function.
