Message 1 of 3
BT Cloud - iPhone Document Backup
Hello. How do I backup my documents on my iPhone? When I look at the settings ‘What to Backup’ Documents are not an option. Thanks
2 REPLIES 2
Message 2 of 3
Re: BT Cloud - iPhone Document Backup
Hi @pddco, sorry you're having this problem with the Cloud.
I've sent you a Private Message so you can get in touch with us and we'll raise this with the Cloud team for you.
Cheers
John
Message 3 of 3
After many weeks (months?) trying to get an answer I’ve just got a definitive answer from the Tier 2 team.
Apparently BTCloud does not back up Documents or Messages on the iPhone - By Design!
So we’ll need to keep using iCloud to reliably back everything up.
Frustratingly the BT Cloud documentation still says that “… it’s easy to backup documents on your iPhone.. “ ( or something similar) I asked if all such phrases could be removed. Very misleading.
