Message 291 of 357
Re: BT Cloud - cannot download all data
have you read this page  https://www.bt.com/help/broadband/bt-cloud/getting-set-up/download-or-access-files/how-do-i-download...
Message 292 of 357
Yes thanks - that's where I started!
Message 293 of 357
Hello guys,
The BT Cloud website is not helpful to those with iPhones/iPads! 🙄😢☹️
or those using iOS. Sad.
It gives help mainly to those using PCs with MS WINDOWS10 and above!
Even so many have said it usually crashes.
The option on the BT Cloud website to “download “ is wrong!
If you’re an iPad user do this:
Go to the BT Cloud website (sign in), tap on a photo to select it (you will see a tick), at the bottom tap “Share to…”(note the share symbol),  tap “Files”, then when you are in Files, tap save to your iCloud Drive (you may have to buy more space from Apple eg 99p/m gives you iCloud+ at 50GB which is more than enough for those who’ve just exceeded their free iCloud storage at>5GB.
You’ll have to do this individually for each photo/video. The download to a zip folder for iPad users will not work. Most frustrating. Luckily I’ve only used circa 4GB of the BTCloud 200GB storage but others will be stuck with huge amounts of data to transfer from BTCloud to iCloud+. Frustrating and sad.
Message 294 of 357
Well, I appear to have solved theproblemby sitting at the computer and refreshing every 5 minutes for around 3 hours...
Message 295 of 357
Well! That’s because you’ve got a PC not an iPad.
Impossible to create Zip files on my iPad so have to save files in batches.
Very tedious!
Message 296 of 357
Such are the problems with overpriced, triumphs of style over functionality that Apple produce.
Message 297 of 357
@licquorice @Or is that people are trying to use a mobile device to replace a PC/Mac and IPad iOS doesn’t play ball?
Message 298 of 357
Re: BT Cloud is closing
Problem for me is that a big download damaged my main hard drive holding all my data. Nightmare.
Message 299 of 357
Sorry this is a bit late in reply.
The key advantage of offsite storage, or cloud as we now call it, is that it protects your data from disaster scenarios like fire, theft, vandalism, flood etc.
I keep a couple of large storage disks and back up (when I can remember) all my key data, but in the event of my house burning down I would be up the proverbial without a paddle.
Message 300 of 357
Sadly it all has to be paid for now!
Unless you have free email with photo attachments which is a way of getting free storage?
BT CLOUD tomorrow will be completely deleted! A positive!
More storage created on your computer by deleting this App.🤣👆At least >400MB!👏☝️
