Message 1 of 2
BT Cloud not activating
Hi, I am trying to access my BT Cloud space for the first time, using the instruction I manage to get to the page on the website where I click  the "Activate" button. When I click it, the loading sequence appears but just goes back to the main dashboard screeen. When I check if it has been activated, it still shows "Activate" on the button and I cannot access the Cloud.
Any ideas, going by other posts is this something that needs fixed from BTs side?
1 REPLY 1
Message 2 of 2
Re: BT Cloud not activating
Hi @BarryMorgan794, welcome to the forum and thanks for posting.
Sorry that you can't access the Cloud service. If you're still experiencing this problem I've sent you a Private Message so you can get on touch with the Mod team and we'll raise this to the Cloud team for you.
Cheers
John
