Message 1 of 1
BT Cloud on a 2018 mac book air
I have 2018 Macbook air, running Monterey. I only appear to be able to access BT Cloud by the web based element, i.e. pressing the globe in the top toolbar. This allows a very slow upload. When the pictures are uploaded I have to select each photo by the 'tick' and then add to album, but on the iPad it is so much easier to create an album. Has the mac based version of the application changed? Is there a better you tube guide on how to use the web based version if that is what I need to use.
