Message 1 of 5
BT Cloud window
Hello,
I have version 22.8.10.0 of BT Cloud running on OSX Ventura 13.0.1 and since the latest update when I click the BT Cloud icon on the menu bar the BT Cloud window opens underneath any other open windows. Prior to the latest BT Cloud version it used to open on top.
It doesn't stop it working but is an annoyance as have to move or close the other windows before I can access the BT Cloud window. See attached photo.
Can this be passed to the BT Cloud team to look into and hopefully fix.
thanks
Ade
4 REPLIES 4
Message 2 of 5
Re: BT Cloud window
Are you also running BT Virus Protect by any chance, if so your issue may be related to this
Norton 360 won't start after updating Ventura to 13.0.1 | Norton Community
Message 3 of 5
Re: BT Cloud window
No I don't have Norton on my iMac.
BT Cloud runs OK and completes the syncing of files it is just the program window opens under other open windows.
Message 4 of 5
Re: BT Cloud window
Hi @Addy, thanks for posting. I've sent you a Private Message so you can get in touch with us and we'll get this sent off to be investigated by the Cloud specialists.
cheers
John
Message 5 of 5
Re: BT Cloud window
Just spoken with BT Cloud tech support and the developers have confirmed this is a fault and will be fixed in the next release of the mac version of the app due sometime in the beginning of next year 2023.
