Message 1 of 2
BT Cloud
Hi, I want to upload photo files from my PC to the cloud, which I can do with no Problem, they are happily sitting in my BT Cloud files folder (web Version)
BUT i don't want to keep them on my PC, so when I upload a file to the cloud it's goes straight in to the BT Cloud folder on my PC, but if i delete that folder from my PC it then disappears from the online BT CLoud folder. I thought there was way that you could tick a box to unsync it from your devices BUT remain on the BT Cloud (Online)???
Cheers
Paul
1 REPLY 1
Message 2 of 2
Re: BT Cloud
If you delete files from the synchronized folder then it will behave in exactly the manner you have described, if you want to back a folder up to the cloud and delete it from your PC without losing content then you need to set it up as a backup folder instead of a synchronized one
