Message 1 of 2
BT Mobile Security
Does the BT/Norton security app for Android phones have a feature that can be used if the device gets lost or stolen?
1 REPLY 1
Message 2 of 2
Re: BT Mobile Security
Hi @SixtiesFan No I'm sorry it doesn't, I've included the features below. The find lock and erase features should already be on your Android device's firmware as standard.
  • Device Security brings real-time protection for your Android smartphones and tablets against ransomware, viruses, spyware, malware and other online threats. It monitors and helps block unauthorised traffic, and helps protect your private and financial information when you go online.
  • Internet Security helps protect your device and personal data from malicious sites that install ransomware, trojans and other online threats.
  • Safe Search is a search engine focused on online security that gives peace of mind letting you know if a site is potentially unsafe – before it’s too late.
  • Safe Web helps provide a safer way to browse, search and shop online. It analyses websites you navigate to, to help detect viruses, spyware, malware or other cyberthreats and provides a safety rating for them, before you visit them.
  • Wi-Fi Security helps detect and alert you when a network joined is dangerous or under attack to help protect your personal information.
  • Norton Clean helps you reclaim storage space on your device by cleaning junk, removing duplicate files and optimising memory.
  • SMS Security helps keep you and your Android device safer from texts with phishing links. It helps identity SMS text messages with unsafe links and notifies you, to help prevent you from inadvertently clicking on them and potentially putting your personal information at risk.
  • App Advisor proactively helps protect your Android smartphone against mobile online threats like malware, ransomware, adware and privacy leaks using a patent-protected app scanning technology.
  • Smart Scan helps you identify security, performance and network issues, and provides solutions to help keep your digital life safe.
Neil
