Message 1 of 3
BT Parental Controls
Hi, I have set-up BT Parental Controls to "Light", but it is not working as I would expect.
On the positive it blocks access to relevant websites, which I would expect.
On the negative I can still search in google for any content I want and see the full search results, such as images.
BT Parental Controls does not seem to affect safe searching.
What am I missing?
2 REPLIES 2
Message 2 of 3
Re: BT Parental Controls
If you are signed into google with your google account, it could be using the safe search settings for that account.  If you try a private window and try searching google (not signed in) the safe search should be on by default (I believe)
Message 3 of 3
Thanks for your reply. I am not logged into google, so would expect the search results to be filtered.
