Message 1 of 11
BT Wi-Fi not turning on
I am trying to opt in to BT Wi-Fi but consistently receive the message “Sorry, something’s gone wrong’ when I tick when I agree with the BT terms and conditions.
Any suggestions?
Thank you.
Tags (1)
10 REPLIES 10
Message 2 of 11
Re: BT Wi-Fi not turning on
It no longer exists, its now EE WiFi.
Message 3 of 11
Many thanks for your prompt response. However I am baffled.
When I go to the My.BT.Com website and my account and when I select ‘Your products’ it clearly states under ‘Included in your product ‘ BT WiFi. When I select ‘Learn more’ I am presented with a screen stating BT WiFi and Free unlimited BT WiFi.
What am I doing incorrectly and how do I access all the hotspots in the UK and overseas?
Thank you.
Message 4 of 11
Message 5 of 11
Thank you.
I have looked at this link but I see no mention on how I may opt in to EE WiFi.
Can you please advise?
Thank you.
Message 6 of 11
I use an iPhone, but Android phones will be similar:
  1. Go to Settings, WiFi and in the list of available networks select “EE WiFi”
  2. You will be directed to a webpage were there is an option that says “Already a customer” with a “Login” button below.
  3. Then from the login screen select “BT broadband account” and sign in using your BT ID.
Message 7 of 11
Thank you for responding.
However before I can sign into EE public WiFi I need to opt into the service.
I cannot see how to do that.
Message 8 of 11
You should be Opted In by default. Are you using a BT hub or if someone else's BT/EE hub close by? If so check as in my post #6 and see if you can login.
Message 9 of 11
I am using my own BT hub and opted out as I was having problems adding a smart item to my network thinking that may have been the problem.
However now I am not seeing the public WiFi SSID’s when I scan the available networks and I can’t find anything about opting into to EE’s public WiFi.
Message 10 of 11
Try phoning customer services on 0330 123 4150.
